> For the complete documentation index, see [llms.txt](https://docs.workersforlabview.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.workersforlabview.io/worker-apis/public-requests-w-reply/creating-public-requests-w-reply.md).
# Creating Public Requests w/Reply
A Public Request with Reply can be created by use of the [Public API Builder tool](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/public-api-builder.md). This tool (shown below) can be found in the [Workers tools menu](https://docs.workersforlabview.io/workers-tools/workers-tools-menu.md) or activated from the [Create MHL Case tool](https://docs.workersforlabview.io/workers-tools/quickdrop-shortcuts/create-mhl-case-tool-ctrl+9.md).&#x20;
Step 1: Select the Worker or Worker base class that you want to create the Public Request with Reply for.
<figure><img src="https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FzuctVwL7nnT7JstmmfOl%2Fimage.png?alt=media&amp;token=44568ff4-8253-48b9-bfcb-f60a9a122953" alt=""><figcaption><p>The Request w/Reply tab of the Workers Public API Builder tool</p></figcaption></figure>
Step 2: In the **Requests w/Reply** tab, select **Create new Request w/Reply**. This will open up the window shown below.
<figure><img src="https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FTrLdjvL1VvsFP4LwCFg5%2Fimage.png?alt=media&amp;token=fe2b53e5-6e8e-46cb-985e-fd4a4bf3beb2" alt=""><figcaption><p>Create Public API Request tool</p></figcaption></figure>
Step 3:  Fields to fill out when you create a Public Request with Reply include the following:
### Request Name
The name of the new MHL case that the tool will create to receive the Public Request with Reply message. This name will also be used by both the Public Request with Reply VI and typedef filenames.
### Icon Text
Text that will be written on the Public Request with Reply VI and typedef icons, to help users to understand which MHL case will receive the Public Request with Reply message.
### MHL Case Description
Provide a description that describes what function the receiving MHL case will perform when the Worker receives the Public Request with Reply message. This description is also written to the Public Request with Reply VI description.
### Create Experimental Dynamic Dispatch Public Request VI (optional)
See section: [Create Experimental Dynamic Dispatch Public Request VI](https://docs.workersforlabview.io/worker-apis/public-requests/creating-public-requests.md#create-experimental-dynamic-dispatch-public-request-vi-optional).
