> For the complete documentation index, see [llms.txt](https://docs.workersforlabview.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.workersforlabview.io/worker-apis/public-requests/creating-public-requests.md).
# Creating Public Requests
{% embed url="<https://youtu.be/mVfYcWxWpP4>" %}
Creating Public Requests - 60 second video tutorial
{% endembed %}
A Public Request can be created by use of the [Public API Builder tool](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/public-api-builder.md). This tool (shown below) can be found in the [Workers tools menu](https://docs.workersforlabview.io/workers-tools/workers-tools-menu.md) or activated from the [Create MHL Case tool](https://docs.workersforlabview.io/workers-tools/quickdrop-shortcuts/create-mhl-case-tool-ctrl+9.md).&#x20;
Step 1: Select the Worker or Worker base class that you want to create the Public Request for.
<figure><img src="https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FVQjdlTXKLeu6fiTQGsSr%2Fimage.png?alt=media&amp;token=de2fcede-582b-4a58-8e36-9a149b7941fb" alt=""><figcaption><p>The Request tab of the Workers Public API Builder tool</p></figcaption></figure>
Step 2: In the **Requests** tab, select **Create new Request**. This will open up the window shown below.
<figure><img src="https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FM2aXfsWXQuyFpgjvt8HM%2Fimage.png?alt=media&amp;token=2ca4e0d7-8dc2-424e-b144-3a9646622543" alt=""><figcaption><p>Create Public API Request tool</p></figcaption></figure>
Step 3:  Fields to fill out when you create a Public Request include the following:
### Request Name
The name of the new MHL case that the tool will create to receive the Public Request message. This name will also be used by both the Public Request VI and typedef filenames.
### Icon Text
Text that will be written on the Public Request VI and typedef icons, to help users to understand which MHL case will receive the Public Request message.
### MHL Case Description
Provide a description that describes what function the receiving MHL case will perform when the Worker receives the Public Request message. This description is also written to the Public Request VI description.
### Create Experimental Dynamic Dispatch Public Request VI (optional)
When this option is TRUE, a Request VI will be created with dynamic dispatch input and output terminals (i.e. the Worker class object input and output terminals). An example of a dynamic dispatch Public Request VI is shown below:
<figure><img src="https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FBLOxYirfLhRuABPmeJxh%2Fimage.png?alt=media&amp;token=9e70b6c6-bed1-455c-8df1-ec37f9d4d307" alt=""><figcaption><p>Worker B : rqp_Return Number.vi (dynamic dispatch)</p></figcaption></figure>
In comparison to a regular static dispatch Public Request VI, there is no output terminal for the Caller's Main Data Wire.
You can use dynamic dispatch Public Request VIs to create Worker Public APIs using Interfaces in LabVIEW 2020 onwards. However the creation of the Interface and the handling of the VIs between multiple Workers that implement the Interface Public Request VIs is not implemented by the Workers 5.0 scripting tools.
In its current configuration, only the required data on the Caller's Main Data Wire will be accessed, and not be copied, when wired to a dynamic dispatch Public Request VI.
