Change Log
This change log shows the changes made between Workers v4.0 and Workers v5.0 only.
Workers v5.0 - Feb 2024 Release
New tool: Workers 5.0 Debug Server (completely refactored, new UI design, new features)
New tool: Workers Public API Builder tool
Create / Edit Public API Request
Create / Edit Public API Request with Reply
Create / Edit Public API Response
Override Public API MHL cases
New tool: Create MHL Case tool
Create / Edit Local API Request
Create / Edit non-Public MHL case
Override non-Public API MHL cases
New tool: Change Worker Properties tool
New tool: Upgrade to Workers 5.0 project tool
New feature: Create Asynchronous Launcher VIs (in Create Launcher VI tool)
New feature: Worker User Library Config File Editor tool (in Worker User Library tool)
New feature: Worker.lvclass Public Properties accessible through class wire property node
New feature: Caller's Public Properties accessible through a Worker's Public Properties
New feature: subWorker's Public Properties accessible through a Worker's Public Properties
New feature: Launcher VIs tab added to Worker Hierarchy Viewer (WHV) tool
New feature: Dynamically Loaded Workers loaded from base classes now detected in WHV tool
New feature: Development tools display progress window whilst tool is performing operations
New feature: Set Initialization Data VIs automatically wired in to Caller's <Initialize> MHL case
New feature: NI VI Icon Library now used to generate all class and VI icons
New feature: Take header colors from other Worker class option added to tools that create classes
New feature: Workers at run-time are now identifiable by a backslash-delimited string (WID). This replaces the period-delimited ID string in previous versions of the framework
New feature: Workers example projects are now available through the Workers tools menu
New feature: All example projects updated. Now use Workers 5.0 generated API VIs
New feature: New DMM HAL Demo Project added to example project list
Upgrade tool changes:
VI name change: Common Cases.vi -> MHL Cases.vi
VI name change: Setup subWorker.vi -> Setup Statically-Linked subWorkers.vi
VI name change: subWorkers.ctl -> Statically-Linked subWorkers.ctl
'subWorkers' cluster in a Worker private data cluster renamed to 'Statically-Linked subWorkers'
Worker and Worker base class background class icons swapped
Other changes:
Worker base class template now contains an Initialization Data.ctl
Worker and Worker base class template now contains a Response Cases.ctl in the class's private data cluster. This cluster is wired to a Worker's Initialization Data.ctl in the Worker's <Initialize> MHL case
Worker base class template MHL now contains the standard 4 Worker 'Framework Cases'
Create Base Class tool now add class icon header string to class XML file
Main VI ref added to Worker Public Properties
Caller added to Worker Public Properties
subWorkers array added to Worker Public Properties
Quickdrop Shortcut Ctrl+9 now opens Create MHL Case tool
Worker detection method changed in development tools, now by class inheritance and not from Alias tag in Worker class XML file
Worker Alias string written to class localized name property of class when new Worker created
Diagram disable structure removed around VTD node with Initialization Data.ctl in Worker template Main VI's MHL <Initialize> case.
When more than one target is detected in the project, the Target selection combo box will appear in the Workers tools menu.
Worker.lvclass : Callback Easy Reply.vi added to Workers palette.
All Case Labels added by the scripting tools are now created in Protected Scope.
All tools that create files can no longer accept \ / : * ? " < > | characters as inputs
Worker Alias string can on longer contain \ character.
Setup subWorker VIs (CNW tool) use ‘To more specific class’ node in place of ‘Preserve run-time class’ node
Format of Worker User Library config files has changed. Now editable with new editor tool.
All scripted VIs and CTLs now contain VI descriptions.
Repeat errors caught by Worker.lvclass:Error Handler.vi are now only ignored IF they have occurred within the same MHL case.
QD shortcut Ctrl+8 (Goto MHL Case) now uses filename after API prefix to determine associated MHL case name. This now works for (future proof) DD override API VIs also.
Worker Hierarchy Viewer tool renamed to Worker Call-Chain Viewer.
Workers 5.0 Debug Server changes:
Task Manger tab -> Application Manager window
Live Message Log logging to file now possible
Clear Log option added to Message Log right click menu
Show/Hide Front Panel option added to Application Manager right click menu
Client mode removed.
Error log file generate by Debug Server application.
Not compatible with Workers v4.0 Debug Client Loader.vi.
Workers 5.0 Debug Client Loader.vi changes:
Debug Client Loader.vi can now detect and display MHL cases in Worker base classes (if MHL case is not overridden)
Debug Client Loader.vi has removed “Server Mode” and “Server Mode : Server Port” inputs, and is not compatible with Workers v4.0 Debug Server.
Functional Change:
Worker.lvclass:Callback Reply.vi now sends upstream error to Worker.lvclass:Enqueue and Collect.vi (or Enqueue Callback Message.vi (poly) in Workers v4.0)
Deprecated / Removed features:
Message.lvclass and Callback Message.lvclass palette VIs deprecated. Messaging now replaced with the new strictly typed Worker API VIs created by the new Worker API tools
Find subWorkers Queue.vi (poly) deprecated
Read Worker Attributes.vi (poly) deprecated
All uses of period-delimited Worker ID strings. Replaced with WID (backslash-delimited string)
Dynamically Load Worker.vi deprecated. Replaced with Dynamically Load Worker v2.vi.
<All subWorkers Initialize> and <All subWorkers Exited> cases are no longer added to a Workers MHL if they don’t exist, when adding a statically-linked subWorker to a Worker with the Create/Add Worker tool.
Bug Fixes:
CNW tool would fail when creating a new Worker in non-English versions of LabVIEW
CNW tool would create a Worker without a Main.vi when creating a new Worker from a custom template Worker
Renaming Case Label tool now deletes old Case Label file from disk
Renaming MHL Case would cause broken link to associated Case Label in VIs that were not loaded into memory
Case Labels can be added to a virtual folder with user defined scope
Efficiency Improvements:
A copy of the Worker's Main Data Wire has been removed from Worker.lvclass:Error Handler.vi resulting in improved Worker MHL loop speed.
Workers 5.0 Debug Server Message Logs process messages at approximately twice the speed of the Workers 4.0 Debug Server, in addition to being separated into Debug Client specific processes.
