> For the complete documentation index, see [llms.txt](https://docs.workersforlabview.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.workersforlabview.io/workers-tools/quickdrop-shortcuts/go-to-mhl-case-ctrl+8.md). Agents can also search and read this documentation through its [MCP server](https://docs.workersforlabview.io/~gitbook/mcp).
# Go To MHL Case (Ctrl+8)
Quickdrop Shortcuts
This Quickdrop shortcut allows you to follow the flow of messages around a Workers application while you are developing in LabVIEW. Activating this Quickdrop shortcut on one of the following VIs will jump directly to the corresponding MHL case of the VI. This Quickdrop shortcut works with the following VIs:
* Case Labels
* Local API Request VI
* Public API Request VI
* Public API Request with Reply VI
* Public API Response VI (this will jump to the location of the corresponding Response VTD VI)
### Step 1: Select a Case Label  or Worker API VI on a block diagram
Select a Case Label or Worker API VI on the block diagram of a VI.
![rqp\_Start.vi (Public Request VI) selected](https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FySQdMTkm6K95dAl6VP2D%2Fimage.png?alt=media\&token=f4517ae3-a005-450f-9587-88f2695f6c08)
### Step 2: Activate Quickdrop shortcut Ctrl+8
With the VI selected, activate Quickdrop shortcut Ctrl+8. The corresponding MHL case of the Worker API VI or Case Label should now appear.
![The Public API MHL case of rqp\_Start.vi will appear](https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2F1r4iLttK87P4x8mhkrBT%2Fimage.png?alt=media\&token=7e26e79a-51fa-4f5f-ba86-931e4209aec1)
