> For the complete documentation index, see [llms.txt](https://docs.workersforlabview.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/worker-call-chain-viewer.md).
# Worker Call-Chain Viewer
The Worker Call-Chain Viewer tool shows you the Worker call-chain hierarchy of a Worker and its subWorkers. The tool shows both statically-linked and dynamically loaded subWorkers.
![Worker Call-Chain Viewer tool](https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FU4eBmIsK92IOhW6DxoUh%2Fimage.png?alt=media\&token=0c02c2aa-0b41-4ca1-a44d-15fe66608dc7)
To use this tool, simply select either a Launcher VI or a Worker from their respective tabs. The tool will then iterate through the selected Worker and its subWorkers, to generate the Worker's call-chain hierarchy, displayed as a tree using the class icons of each Worker or Worker base class.
## Options
### Launcher VIs
The Launcher VIs detected on the selected target.
### Workers
The Workers detected on the selected target.
### Refresh
Will refresh the list and redraw the tree.
This tool works well together with the [Create/Add Worker](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/create-add-worker.md) tool. You can have them both opened side-by-side, and every time you add a new Worker to your application with the Create/Add Worker tool, you can press **Refresh** and see the addition of the new Worker in your application.
### Save Image
Allows you to save the generated image as either a PNG, JPG or BMP file.
### Options
#### Show Worker Icons?
Includes the Worker icons when drawing the hierarchy tree.
#### Show Worker Names?
Includes the Worker names when drawing the hierarchy tree.
#### Show Worker Alias?
Includes the Worker alias when drawing the hierarchy tree.
{% hint style="warning" %}
The alias for the hierarchy's head Worker and dynamically loaded Workers is not shown.
#### Include Dynamically Loaded Workers?
Includes Dynamically loaded Workers when drawing the hierarchy tree.
