> For the complete documentation index, see [llms.txt](https://docs.workersforlabview.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/change-worker-properties.md).
# Change Worker Properties
This tool can be used to change the following properties of a Worker or Worker base class:
* A Worker's class name. Changing this property will change the Workers name in the following places:
  * Class filename will be renamed
  * Class folder (on disk) will be renamed
  * All references to the class and its VIs/typedefs will be relinked within the scope of the project
  * All class object labels on all VI front panels (within the class) will be renamed
* A [Worker's Alias](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/create-add-worker.md#worker-alias) (not available for Worker base classes)
* A [Worker's Icon Header](https://docs.workersforlabview.io/workers-tools/workers-tools-menu/create-add-worker.md#icon-header)
The Worker's Icon Header text is a tag stored within the class's XML file. It is used to write text on the name of scripted VI icons, such as a Worker's Launcher VIs, etc.
<figure><img src="https://2767648102-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FZWihGdeYUalj239OUdAB%2Fuploads%2FLIRZQemUnGDQ0t3uhWBP%2Fimage.png?alt=media&amp;token=41767864-05ed-4255-9339-5b89234d4cd1" alt=""><figcaption><p>Change Worker Properties tool </p></figcaption></figure>
